sealant
waterdawg69
im in the process of repacing my u-joint. the bellows are not even a year old can i reuse it, and what type of glue/sealant do i use to put back on it?thanks
Bt Doctur
Re: sealant
servicing the U joint has nothing to do with the boot???
Bt Doctur
Re: sealant
you unbolt the drive from the gimbal to service the joints ,the boot connects the gimbal to the transom.nothing to do with U joint reoplacement
Don S
Re: sealant
Here is a Gimbal Ring
This is a Gimbal Housing sometimes knows as the transom shield
This is the Bellhousing, sometimes called a pivot housing
This is a Gimbal Bearing
As far as I know, there is nothing on the back of the boat called a Gimbal
Bt Doctur
Re: sealant
Ooops,your right Don. Sometimes call it a "helmut" but pivot housing is more correct.
