Sealing an oil exchanging cavity gasket
Safari
After experiencing the difficulty of finding N.L.A. gaskets for my old MercruiserII leg, I have a statement and question.<br /><br />I found a gasket for an exorbitant price and not wishing to go through that experience again, decided to buy a sheet of gasket material and make some duplicates for future use. I installed the new gasket(sealed it with 3M weatherstriping seal), pressure tested and found a leak in yet another oil seal. Then I had to separate the two sections again. In doing so I found the 3M worked very well indeed, ---too well! I destroyed my new gasket in the process. Cutting new gaskets with an Exacto blade is time consuming and I don't like doing it. I might have to take these two sections of the leg apart again and am looking for a way to not destroy this second gasket.<br /><br />My question is, can I get away with applying grease to both sides of the gasket then put the two sections back together? Or, should I seal one side only of the gasket? Or,do I need to, yes indeed, seal both sides.<br /><br />You folks have been very helpfull in the past and I am looking forward to your suggestions.
tommays
Re: Sealing an oil exchanging cavity gasket
Sarari<br /><br />most people seam to fing that silicon sealers cause problems anywere when its below the waterline it seams to be able to get a galvinac reaction going<br /><br />merc perfect seal seams to work very well and will not cause problems but would also damage the gasket if you need to take it apart<br /><br />reuseing a gasket is a bad idea anyway they really only seal well one time you may or may not get lucky the second <br /><br />grease really does not have any long term sealing ablity<br /><br />tommays
trog100
in theory gaskets should only be used once and if the mating surfaces are good should not need any sealant.. mostly they get some just in case..<br /><br />in a perfect world when u take something apart the gasket stays nicely stuck to one side and comes cleanly away from the other without any damage.. if it dosnt it needs replaceing..<br /><br />if u plan on taking something apart several times u can arrange this ideal world situation by useing sticky gasket sealant on one side and just a smear of grease on the other.. it u intend it to stay together for ever just gunge it up with any old none soluble sh-it and forget it.. he he<br /><br />i think mostly gasket sealant used wrongly can do more harm than good.. or at least as much..<br /><br />shadetree theory this by the way.. not professional..<br /><br />trog100<br /><br />ps.. silicone in tubes is a much overrated and over-used product.. very good for sealing round your bath-tub but not much good for anything else..
rodbolt
gotta agree with ya here Trog :)
Buttanic
Try Permatex Hylomar HPF. It won't stick everything together but it will seal it. It's the best sealent I have ever used for parts that need to be taken apart frequently without destroying the gasket.
