Sealing engine to transom
Jim13
What is the proper way to move your engine up a notch?
I noticed there is some sort of sealer around my bolts. Should the engine have sealer around it also?
bomar76
Re: Sealing engine to transom
Wayyyyyy to much information.....try posting less.
We are all mindreaders here and love a challenge!!!
xtraham
put a jack with a piece of wood under the skeg of the engine, loosen bottom bolts, remove top bolts, jack engine to the desired hole and use 5200 marine sealer around the bolt holes..
calwldlif
I wouldn't use 5200.
4200 is easier to remove if you have to.
If your putting it there perminent the 5200.
Jim13
Thanks guys!!
Should I run a bead around where the motor touches the boat also? Or is this overkill?
roscoe
Just seal the bolts.
