Sealing small hole in transom
muskrat808
Hi- Replacing transducer mount on aluminum Starcraft and previous owner drilled one too many holes and sealed with adhesive . What is best way to permanently seal a small # 8-10 / screwhole ? Screw with adhesive ? Some kind of aluminum hull sealer ? Thanks
robert graham
Re: Sealing small hole in transom
Maybe just stick some silicone in the hole then put the screw in it. The transducer screws on my aluminum jon boat go all the way through the 100" thick aluminum and I seal them inside and outside with clear silicone...never leaked so far! I've also used a small stainless steel screw and nut to seal hole in my aluminum canoe...still no leaks!.... lots of ways to skin that cat!;)
BRICH1260
I`d probably use something a little more permanent that silicone caulk, such as an epoxy or a boat specific caulking designed for below waterline use.
Hank496
If you have access to closed end aluminum pop rivets, a rivet with two aluminum washers and a healthy does of a permanent caulk will do the job. If you can't get the rivets, get an aluminum bolt and nut and do the same thing, just round the thread end down so the nut won't back off.
Philster
5200 sealant with the rivet or screw
Solittle
Marine Tex - two part epoxy and cures like steel.
smokeonthewater
Do not use silicone and epoxy is not the best solution for aluminum......
as philster said 4200 or 5200 and a screw or rivet.... for that matter for a small hole under 1/4"the 4200/5200 is fine by itself if you need it flush.
If you want the ultimate (extreme overkill) fix take it to a welding shop and have it welded
ps robert grahm, I've never seen a boat with a 100" thick hull..... must be a heck of a boat LOL
5150abf
When I painted my boat 2 years ago I filled all the holes in the transom with JB Weld then sanded them down and painted and it has held up really well but the easiest fix is 5200 and a stainless screw.
giericd
I have to agree with the 5200 and screw! that 5200 is amazing stuff
ezmobee
I filled a number of necessary holes in my transom with JB Weld also. I used little squares of aluminum flashing on the inside to act as a "backer". That allowed me to sand it smooth on the outside with the plug of epoxy "popping".
Philster
JB is good, too, but where flex might be an issue, JB Weld's strength (being very rigid/solid) might work against it.
But in most cases, it'd be fine.
robert graham
Yep, it's a really thick hull!::p .100" is closer!
