Hello everybody,
I have new thermostat,new thermostat housing ,still i don't Know if the temperature is ok.With the thermostat out ,the needle at idle in gear it just passes the yellow region(the first small box) and at 3000 rpm it hardly reaches the center.With the thermostat in ,at idle in gear, the needle is at the center,at 3000 rpm it slightly passes the center but when i slow down the needle aproaches the red region for a while and a few minutes later it returns to slightly more than the center.Supposing the temp sender and the gauge are good may you tell me if the behavior of the gauge sounds ok to you?Thanks in advance.
