Sears 3HP - dies under load
watercruiser
My older air cooled sears, runs well, revs well but after a few minutes it dies off under load. I let offf revs and it prevents it stalling. I am sure it is starving from fuel at high rev. Is there a diaphragm in the carb on these machine?<br />Maybe the fuel lines are collapsing ?<br />Any suggestions ?<br />Many thanks<br />Alan
CATransplant
Re: Sears 3HP - dies under load
Check for a vent screw on the cap of your tank. Loosen it.
Coffeeguy
What he said, or...I've got one that would run just fine in the tank at home, but once I got it to the lake, NOTHING! This was after cleaning the carb and the entire fuel system and tweaking the settings. I noticed it would also drip fuel after a couple of minutes; turned out the float needed adjustment. That can also starve the engine for fuel; at higher RPM's and under load, the engine uses more gas at which point the float drops, which lets more fuel into the bowl. Once the float reaches the top, it closes a valve so the engine doesn't flood. If the float isn't dropping when it's supposed to, or the valve is sticking, the engine gets starved for fuel and will die. If you've got a service manual it'll tell you how to adjust the float, and if not, just experiment with moving it up or down and see if your situation improves. There can also be, as was suggested, a restriction in your fuel line, vent on the tank, or fuel pump if your engine has one.
24tesla
I am unsure of the 3hp, but mine is a 7.5 and was dying under load. Turns out I had 2 problems. I had to replace all the hoses. The one in the housing and the one from the tank to the motor. And the carb has a diaphram, mine had a split in it. If you have this and need to replace, find out the angle the slit in the face needs to sit. Again mine is a 7.5 Gamefisher and the slit sits in the 2 and 8 position, or more accuratly, at a 45 degree angle from the bolt hole center line.<br /><br /><br /> http://home.earthlink.net/~brixent/ has parts, as well as Sears.
