Re: Sears 7.5 Throttle Linkage
uh lets see you changed the flapper valve and fuel pump? you moved the throttle cam? several things to note hear, flapper valve can be backwards and or the gasket is messed up pulling air, fuel pump inlet can be a little tricky,
the throttle cam has to be sinked with the throttle and timing, usally its just the new carb gasket thickness and age stress on the brass rods mounting point, I just bind that up till I get wide open throttle plate when twist grip is moved all the way to fast, go back through your flapper valve, make sure your fuel pump is good and set correctly, and set your cam back like it was, hopefully the witness marks are there, and then adjust the throttle plate rod like I describe, and above all else get a manual and follow the instructions.
if all else fails donate it to me and I will fix it tomorrow and sell it back to you for a nominal fee
plus shipping...
stay with it, don't give up its to simple...really
