loose rivet
- Jul 31, 2011
- 151
About a year ago I was given a 14' Sears row boat which appears to be identical to and made by Alumacraft.
The last owner had a 40hp Gale on it, which took a toll on the transom panel. Upon removing the rotted wood, I can see where the smaller inside panel has indented the transom quite a bit. There's crease about 15" long about mid way and the outer plywood panel has taken a curved, permanent set.
What I'm thinking about doing it making the inside and outside panels the same size.
Basically I'll cut the outer panel to stock size, then cut the inside panel about an inch taller to bring the wood to the very top flush with the transom. I'll wrap the very top with aluminum incorporating a clamping pad in the bent inside metal.
I'll be using pressure treated 3/4" plywood since when this is in the water, the lower half of the outside wood is submerged. I'll drill, sand and epoxy coat the plywood and paint the transom panel in and out to help protect it against corrosion from any thing in the wood. The plywood has aged about 4 years in the garage, so it's pretty dry too.
I'll replace all the rusty hardware with stainless Bolts, washers, and Nylock nuts sealing all holes with 5200.
My guess is that this panel will outlive me.
No, I won't be running the 40hp on this. I can't even imagine what it handled like. Amazingly there's no other damage or leaks. At best it'll see a transom trolling motor or my 9.5hp Evinrude. (It's rated at 20hp on the plate.)
