DamianJP
- Mar 25, 2008
- 612
Hello
I'm selling a SEARS Gamefisher 5hp Model number 217-586612 and want to get it in %100 running order before I do.
Things I need help with
1) Fires up but bogs down randomly , the carb needs a rebuild.
http://www.searspartsdirect.com/par...00048787/00007?blt=06&prst=0&shdMod=217586612
I notice the needle / seat and the 2 fuel pump/intake gaskets aren't available, what can I use as a direct replacment?
2) Started recoil needs to be rebuilt as the Dog/ Starter doesn't pop out everytime and only catches randomly.
http://www.searspartsdirect.com/par...00048787/00009?blt=06&prst=0&shdMod=217586612
The Dog/Started piece isn't available too. Do you think it's just the return spring or something else I can replace?
3) I see a water pump in the schematics, it doesn't have a pee stream outlet. Should I get mist from the exhaust to see if it working and what temps do these engines run at to test with my IR Thermometer?
http://www.searspartsdirect.com/par...00048787/00005?blt=06&prst=0&shdMod=217586612
Any help would be greatly appreciated. And if you know were to get NLA parts for this motor would also be cool.
Thanks,
DamianJP
Thanks,
DamianJP
