Seastar hydraulic fluid
tony1224
I am trying to find out what different type of hydraulic steering fluid will replace or aftermarket,for a seastar hydraulic steering.
F_R
Re: Seastar hydraulic fluid
This is embarrassing. I used to bottle and label the stuff. I THINK the number is 5606 Aircraft Hydraulic Fluid.....As I remember it. Aircraft because of the wide tolerance for temperature. An airplane may be sitting on 100 degree tarmac and five minutes later be in sub-zero temperature at high altitude.
dehydrated
Thought id better look it up TexacoHO15,Aero Shell fluid#41,Esso Univis N15,Chevron Aviation Fluid A, Mobil Aero HFA and as F R has stated Mil H5606 specs . thing ive found is the avaition fluids are a lot less dollars to buy
dehydrated
Look at any petroleum dealer use your phonebook or small airport
tony1224
Thanks guy's.good forum.I always get help here.Keep it up
