seawater pump impeller
jhilton
What does the rubber plug that you push in the impeller to the back of the housing do? Is it needed?
Re: seawater pump impeller
Ayuh,... On What,..??
HT32BSX115
On a seawater pump 1994
Lessee.......94 sea water pump........I'm trying to guess....:confused::confused:
You're just going to have to be a little more specific.
Could you narrow it down a little... please ? Dana, Scott Atwater, Lauson, OMC, Volvo Penta, Mercuruiser (Alpha or Bravo)l
Well I guess Scott Atwater, Lauson, are out of the picture...they weren't around in 1994.....
jhilton
mercruiser seawater pump 7.4 liter, crownline 250, 1994, carburetor, one piece body on pump and it is mounted on the starbord side.
jhilton
It was not on there, i only have an old manual. Thanks. What is the quad ring?
jhilton
Seems that everybody likes to reply with not enough info until they have it all. The quad ring,(after 4hours on the phone) is just an o-ring. never mind!:rolleyes:
Philster
Eventually they tire of making an effort when the person in need of help won't make the effort. Understandable.
