- Mar 8, 2009
- 42,891
If you have an engine mounted mechanical fuel pump which looks like this on your engine.
The pump could be leaking gas into the fuel pump cam mechanism and you may not find out for some time. In older days the fuel pump was mounted to the engine, and if it leaked a little bit, it would be removed when you changed the oil. See the vent port is low
With it being mounted on the sea water pump, the gas will get mixed with the oil and will cause wear of the seals and cam lobe. If it leaks slow enough you may never know until water starts coming in the boat from the seal failure. The reason for this is the vent tube when mounted on the seawater pump is higher. In order for the fuel to reach the tube it must fill the seawater pump cam housing and the fuel pump before it will reach the vent port.
The seawater pump in the picture above uses gear lube in the fuel pump cam area. The seawater pumps of this type can have one or two screw fittings. The one above has only one screw fitting, which is the fill port. If anything comes out when the plug is pulled you have gas or water leaking in. If it is water it will look milky, gas leak will thin the gear oil. If a little gas is found you should drain and refill with fresh gear lube. If you get more than just a little you should replace the fuel pump and inspect your seals.
Seawater pumps with two screws will have one on the bottom which is a drain. Those with only one will need to use suction to remove the oil from the top plug then refill.
