see sawing
floater212
how do i figure out what's wrong with my boat (too far foward or too far back) or trailer (new spring and tires), on the highway i take to get to the water bumps big, of course, and small the boat starts a seesaw action that drives me crazy...short drive! it had this from the start of when i got it. the tow vehicle is a 2012 ford 150 4x4 so it's stout enough, i changed rear shocks to high pressure gas and added a sway bar which helps but still there. i have never changes position of the bow stop because i don't know which way , i am thinking of the load leveler coilover shocks. which way should i go for? my boat is a 2005 rinker 212 ( 3500lbs) and single axle trailmaster, they call it a heavy single.
roscoe
Trailer frame should be level when hooked to the truck, you may need to buy a different tow bar to achieve this.
And yes, you need 350 + pounds of tongue weight on the ball.
Move the boat forward or the axle rearward, to increase tongue weight.
GA_Boater
If it hasn't been said - Increase your tongue weight. Can you pick up the tongue?
floater212
i don't know the tongue weight, how can i find that out, i don't have a scale to go up that high so how do i do it?
MTboatguy
Do you have a picture of your trailer hooked up to your tow vehicle? as was already asked, can you pick the tongue up by hand, if it is off balance, which what a light tongue will do, it will cause that oscillation you are describing when it hits ripples in the road. The boat and trailer being heavy in the back is trying to pull it off the ball which causes it to "see saw" back and forth.
move your bow stop forward or move your axle backwards
you need more tongue weight
khe
If there is a CAT certified truck scale near you (it seems like they're everywhere) you can weigh your truck and boat as a unit - your weigh ticket will show: Steering, Drive, and trailer. Once you have your weigh ticket, move to the parking area, unhook the boat and weigh just the truck. With the two weigh tickets, you can do the math and figure the tongue weight: Add the steer axle and drive axle weights together from the weigh ticket with the boat hooked up. Add the steer and drive axle weights for the truck only. Subtract the truck only weight from the truck only with the boat hooked up and you have your tongue weight. To calculate the weight of the boat and trailer, subtract the gross weights. Divide the tongue weight by the weight of the boat & trailer to obtain the percentage.
EZ Loader recommends 5-7%
Silvertip
You do not need a 400# scale to measure 350 pounds. If you have a bathroom scale, it will likely measure in excess of 200#. You obtain a 2x4 about 3 feet long. Place a mark exactly in the middle of that 2x4. Place one end of the 2x4 on the scale and the other end on a block (wood, concrete, etc). Just make sure the 2x4 is level. Now set the coupler (or the tongue jack) on the center of the 2x4. The scale will read 1/2 the tongue weight. This isn't rocket science so an error of 5 - 10# is not critical. It is meant to give you an idea what the tongue weight is. Right now you don't have any idea.
JASinIL2006
Whatever you do, find out what the tongue weight should be and fix it. You can go from see-sawing to out of control before you know it.
M2HB
As a general rule, 10% is a minimum tongue weight.
Too little tongue weight can rip the trailer off the tow vehicle if the sway gets bad enough.
I try to keep it over 10% since I pull with a one ton truck.
The problem with low tongue weight is if something shifts or weight is added in the back, like water in a boat, it can cause a wreck.
floater212
how would it act if there is too much weight on tongue? just for fun i tried to lift hitch up and there has to be about 400lbs +, couldn't even budge it at all.
Alumarine
Unless you can lift 400 lbs you won't be able to budge it.
M2HB
Extra tongue weight won’t create issues if the tow vehicle can handle it and the tongue can handle it. In many cases, one or the other may not handle the extra weight.
MTboatguy
Actually if you are heavy in the tongue where it is actually dragging down the back of the tow vehicle, it can cause a seesaw effect on concrete slab roads, the joints of the slabs sit higher than the middle of the slab and as you go over the joint the extra weight of the tongue will load the springs more and cause a opposite rebound causing the tongue to spring upon unloaded state. It does not take much release and rebound to make them seesaw if things are out of balance.
If you have a few cinder blocks around you can shift your load to see if you can't smooth it out a bit, I would put a few in the stern on the floor then take out and drive on the type of road that you experience this situation and it will help you determine which direction to go to correct it.
floater212
moved bow stop towards truck 1", seems alot better, we'll see after a few more hauls...
