Why the heck don't boats come with checkvalves on the drain plugs? Forgetting the plug seems to be THE most common oops. I have two Sea-doo PWCs and a Regal bowrider. The 10k seadoos each have two drain plugs complete with check valves to prevent that oops. However the 40k regal does not...seems odd. Heck it's even available:
unifiedmarine.net/cgi-bin/htmlos.exe/0063.10.889260536500031619"]check valve plug fitting
Anyone installed one of these? Only down side I can see is something clogging it up and partially open, which is less likely in the sea-doos
