Justafarmer
- Sep 2, 2018
- 2
I have lurked on here for some time but this is my first post. I recently purchased an old Starcraft Holiday 18 with a seized 3.7 engine and an alpha one drive. It was supposedly running well when "parked" 5 or 6 years ago and properly winterized. The boat is going to need some work and I was hoping to get lucky freeing up the stock engine. No water in the oil and coolant is topped up. I've been adding small amounts of oil/penetrant to spark plug holes over the past several weeks. At first the oil would seep through on cylinders 1, 2 and 4 (counting from bow to stern). Cylinder 3 held the oil for the first couple days and now it drains out as well. I am using a large breaker bar to put gentle pressure on the crank bolt to try to rotate the engine but it is still stuck solid.
I realize that ideally the engine should be torn down and investigated but is there any other suggestions of what I could try to free it up. I am thinking about pulling the front pulley to see if anything external could be causing it to be stuck. I have read on here about all of the flaws of the 3.7 which is why I am looking to find an inexpensive way to assess this engine. If it's not going to free up then I may spend my money on something that had a better track record.
I also have a chance to buy an inline 6 mercruiser 165 for a reasonable price. Could anyone help me with figuring out what engine would be a good swap for what I already have (3.7 and alpha one)? Is there an engine that is compatible with the existing transom plate and drive or do they each have different set ups?
Thanks!
Thanks!
