Re: Seized thermostat bolts
You might as well use water as to use WD40 as a penetrant. Get something serious like Liquid Wrench or PB blaster. Once you have liberally applied it start by rapping on the bolt using a drift punch. That will help break loose the rust holding the bolt. You may have to apply and rap numerous times over several days before they let loose.<br /><br />Also, if you have a propane torch and can carefully apply heat, just to the bolt head then quench with cold water, the expansion and contraction will aid in loosening the bolts. <br /><br />Sometimes patience is the key.
