Re: Self-Bailing Help
I put two small scuppers on mine, and made it so that I could plug them off with regular old 1" drain plugs if necessary... <br /><br />Pros, water goes out when moving forward... Thats a good thing cause it's a wet ride.. took a few waves over the bow...
<br /><br />Cons, and i'm just going by the way mine sits in the water.. The floor is about an inch above the waterline at the transom.. I get some water comming in when sitting in a sea... not much, but a little.. <br /><br />Actually, now that i think about it, mine is totally different that yours now, and mines probably a bit heavier too... Yours has the full inner liner with the compartments in the transom, mine don't anymore.. Hummmmm. <br /><br />From what I remember, I think you could do it with 4 thru hull fittings (2 slightly modified for the inside to fit closer to the floor), a length of hose, and some creative engineering...
