Re: Self test horn kit
The Morse control has nothing to do with the warning system, it is the instrument cable leading from the engine to the instrument/control center that handles that.<br /><br />The self test type warning horn can be purchased at any Evinrude/Johnson dealership, and possibly other sources that I'm not aware of. It is a three wire horn, one black ground wire is a permanent wire, the other two being push on connections.<br /><br />There should be a TAN wire leading out of the front of the instrument cable. That TAN wire would connect to the terminal closest to that black wire.<br /><br />There will be a "A" terminal on the ignition switch (12v only when the key is ON). Run a wire from that terminal to the other push on terminal of the horn.<br /><br />The black wire from the horn goes of course to a known ground.
