My engine is a 1980 Johnson 70 hp. The carbs have been rebuilt correctly( soaked overnight in carb cleaner all passages blown out and put back together with OMC kits). Compression is good 130, 130, 125. Spark on all three clyinders. But my engine will not run at all when follwoing the sync and link procedure in the Seloc manual. The engine will Idle with the cam follower sitting at the start line on the timing cam, but not the short line as the seloc manual says. Since I can,t get it to idle in the correct position I can,t go through the rest of the procedure. Any advice?<br /><br />Thanks <br />Will Vaughan
