Sending unit pink wire
JOFO17
Is there any way to test the pink wire from the sending unit without cutting it? I have a NEMA sending unit and dont want to have to cut and crimp again if I can avoid it. I just put in a new tank/sending unit and it is empty but reading below empty as if no signal. I tested the guage and it functions properly.
Its a resistance range. Use an ohm meter
R055
You can always run a new wire to the guage just for testing purposes or as suggested above.
