Re: sending unit
Two wires to the sender. One should be black and the other should be pink.<br /><br />The black wire will go to either a flat tab that is somewhere off center onthe sending unit and then will run to the back of the guage to the terminal marked "G". The pink wire will connect between the center stud on the sender and the terminal on the back of the guage that has an "S" next to it. Finally, at the guage, there is another terminal that will receive power when the key switch is turned on. That's all there is to it. <br /><br />Thom
