serial number i.d.
marin001
i am coming into a evinrude 10hp 1962 motor and would like to know if i can find out whether it is a short or long shaft with the serial number
10024A 01953, thanks
JimS123
Re: serial number i.d.
10024 is a short shaft.....10025 is the long.
F_R
The numbers only applied when the motor left the factory. Some of them got changed back and forth several times since then. It is easy to tell what you have, simply look at it. A long shaft has a very obvious 5" section added between the lower unit and exhaust housing. If you can't decide whether it is there or not, it isn't.
