Serial numbers don't match
Epliett
I have a 1978 260-350 I believe. Theres no serial # any where on the engine to confirm what yr. it really is. It is a 350 Gm. I confirmed that. It looks to be a rebuilt motor, an not original. My sterndrive has a serial # stamped on the starboard side of the upper gear housing # 2729711. I had the stern drive rebuilt, an I was told it was a Merc MR 1:50 ratio. Can this be? I can't match this serial # up with any Sterndrive charts that I 've looked at. No, the casing was not replaced at the rebuild. Is it possible this sterndrive was converted to a 1:50 ratio drive, in a old casting? Boy do i have alot to learn.
ED
Re: Serial numbers don't match
Ayuh,...
Being a 1978,... I'm not at All surprised it's not original...
The transom assembley is probably still the Mod.1,... Alphas,+ the MRs are a plug,+ play swap....
The 1.50:1 is what's Supposed to be behind a V8...
Ditto on the motor,.. Other than a few design changes over the years,...
An SBC is still an SBC...
Epliett
Thanks once again. I'm new at this marine stuff. Its my first project boat. I got it from a estate where the fellow passed away. I'm just winging my way thur. Thanks for your help. Sounds like I at least have the right combination.
ED
Ayuh,... Have you been to the Adults Only section of the forum,..??
There's a Gold Mine of information there, including the factory service manuals for your driveline....
Have a look...
Epliett
Bond-o, yes I have been there. I downloaded 3 manuals. Mostly the ones for the engine. I'm gona revisit it tonite, an check out whats available on the sterndrives.
Thanks Ed
Epliett
Bond-o,,,could you explain in short, the difference of Alphas/MRs vs.Tr/TRS
I can not relate to what one or the other is.
Thanks Ed
Ayuh,....
The Alpha drives are the typical Chevy sedans of outdrives...
The TR/ TRSs are like a Bulldozer,... They're Monsterous drives,.. You Don't have 1...
