Serial # of engine 88 sea ray Seville & carb info
pgiese
having a hard time finding the serial # for the engine of our 88 sea ray Seville,need to know carb info too
Ayuh,..... Welcome Aboard,..... We can't see it from here,.... Ya gotta give Us a few hints,.....
If it's still there, there should be an aluminum tag riveted to the block, down low, aft, just above/ behind the starter,....
2bbl. or 4bbl. carb,..??
Fun Times
Hi there pgiese, welcome to iboats!
For a starting point, What size engine do you happen to have in your 1988 Sea Ray?
See if the following link covering Where to Find Mercruiser Stern Drive and Engine serial numbers will help you out any.
Drive units
In-line Engines
V6/V8 Engines
