Re: Serious Piston Damage
It could be a couple of things, one being the carb - that cylinder could have "leaned out" meaning it was getting too much air and not enough fuel - often caused by an air leak in the intake somewhere, incorrect carb settings or a dirty carb, or possibly even worn out reeds. I agree with PeteMax on this - pull the head(s) off and turn the engine over by hand and inspect the cylinder walls, if they're deeply scored/scratched you'll need to bore, if they don't look too bad then the thing to do is get a ball hone and hone out the cylinder - best hones to use are called FlexHone (which you can see at
www.brushresearch.com then click on Flex Hones on left side, use around 400 grit or so). It's fairly easy to hone yourself, it just goes on a drill, you use LOTS of oil, and while spinning move up and down cylinder to create a "cross hatch" - if you're unsure you can find out more on how to do it on the web, or get a book. Be sure to wash block COMPLETELY - it's recommended that it's rinsed thoroughly in (believe it or not) hot soapy water! You need to dry it competely and oil it immediatly after washing though or it'll rust and you'll ruin it. <br />The other possible cause of the problem here - if the piston was pitting away on the dome (top) of it near the center - like where the spark plug is? It's possible that you have the incorrect spark plug heat range in there and it's burning too hot and literally melting away at the piston - I've seen this in other 2-stroke engines, but I'm quite sure it can happen in any, including boats. <br />good luck.
