Setting 3.0 valves..need help
Nickdogg
My motor is a 1990 omc 3.0 4cld Gm,can anyone tell me what the valve settings are????
Re: Setting 3.0 valves..need help
Ayuh,... Tighten to Zer0 lash, Plus 1/2 turn...
CobiaXL
Banned
Bring piston up to TDC on compression stroke and adjust both intake and exhaust.Find zero lash by moving push rod up and down,when all play is removed,That's zero lash.Then go 1/2 turn after that.Then move to next cylinder and repeat.
