Setting points/dwell
mick97
I have a question on setting points.
I will have points and condenser on wednesday.
I haven't worked on points for a long time.
What would be the dwell to set them at on a 4.3 omc 1987?
Its a 1987 galaxie boat.
Im thinking its around 47?
So basically I would turn the shaft to its highest point set the points open and stick in a matchbook right..lol
Like I said,its my first time with a omc,and a long time with points.
I had no spark,so thats the reson I got new points.Just going through it one piece at a time as it has been sitting for 4 years.ouch..
And I need to learn a little more for when the parts come in.
Scotty
bruceb58
Re: Setting points/dwell
You set the dwell angle with a dwell meter. The alternate way, which isn't nearly as good, is setting the gap with a feeler gauge. Dwell should be 39?.
After you set the dwell, you need to adjust the timing with a timing light.
Timing should be set to 6? BTDC.
You need to buy a factory OMC manual(not seloc or clymer) so you know what these setings are supposed to be.
mick97
Thanks Bruce.
Yes will get a manual sooner or later.Just want to see some spark first.ha
Thanks for the settings info.
I'll post my results i a couple of days after parts get in.
mick97
Thanks for the thread link :)
mick97
Does anyone know the point gap on this?
Is it 18?
87 omc 4.3 liter
Scotty
bruceb58
0.019
I really suggest you use a dwell meter though. The added benefit of using a dwell meter is to see how steady your dwell is over RPM. If the dwell is changing with RPM, it means you have worn bushings in your distributor. Dwell that changed also means your timign is changing when it isn't supposed to.
mick97
Im not too sure how to use one anymore.Been years.
I would be green for sure.
mick97
lol.
Ok.
If these new points give me spark,which i didnt have,I will go and get one.
Didnt think id ever go back in time.ha
Thanks again.
Points should be here tomorrow.
mick97
Thanks,
Will have to look it over :)
Where are the timing marks located?
I believe someone said 6 degrees for a 4.3 correct?
I put a clamp on the positive of the coil correct?And then clamp over the #1 plug wire correct?
Looking at the motor,which one would be the number one plug wire?
Just put new points in and condensor,and got a spark finally.whew........
So I just needed the procedure,so when i put it in the lake,i can walk through the steps.
Thanks so much
Scotty
etracer68
Ensign
If your asking about a timming light, there should be two wires, one pos, and one neg. They hook up to the battery, and then the clamp type to the number one spark plug wire. The marks should be on the balancer, or damper.
mick97
ok thanks.
Ya its been awhile,lol
So can i just get by setting it,and then using a feeler gauge?Resetting it after timing it.
Really dont know much about dwell meters.The guy at napa said its really not necessary.
But Im guessing if its not set close,i will burn out the points a little quicker possibly.
But i plan on changing them each season anyways.
mick97
Ok,
I have the points set to 19 as I believe I was told.
So next set the timing right?
Then I will have to reset points?
Scotty
mick97
Well thats cheap enough for a dwell meter,thanks.
Will have to learn how to do that I guess.lol
Thanks for the link.
bruceb58
Ok,
Scotty
Again....once you set the points you don't touch them. Set points to proper dwell and then adjust timing. Adjusting the timing is always the last step.
mick97
Thanks very much for your help.
I'll be getting a timing light later this week,and a dwell.
I'll repost when I get to that point :)
Hopefully all goes well..
Scotty
mick97
I got it runnin,but only if i spray gas into the carb,and keep spraying.
i did take out the fuel pump and thought i cleaned it,but when i go to choke it by pulling out the throttle and pumping it,nothing is going to the carb.
Was thinking big deal at first because its only the choke and i can put gas in the carb to get it going.
I put the fuel pump back on.
The rod was sliding out and stopped at a certain point.
So when i put the fuel pump back on,i just butted it up to the rod,and pushed the pump back on.
Seemed to go on without a hitch.
Not really sure,but mabe i should take the pump back out hu?
I was thinking the rod and remounting the pump was alright.
Any suggestions?
Scotty
