KillerKilgore
- May 29, 2010
- 50
I just changed the points and plug wires on my rude and was just wanting to know where the throttle should be set.
Was doing some research here and found this thread
http://forums.iboats.com/showthread.php?t=294072
It did not mention where to set the throttle. Then found this thread
http://forums.iboats.com/showthread.php?t=281957
With this post (#23 on the previous thread)
http://forums.iboats.com/showthread.php?t=281957&p=2595571&viewfull=1#post2595571
Then the post under it answered his question.(#24) (said it did not matter where the throttle was set)
On my engine when I have the throttle wide open (the position I adjusted mine) I can put the feeler gauge in.
When I move the throttle down to halfway and rotate the cam to the position where the points open.
I cannot insert the feeler gauge until I move back to full throttle and rotate the cam again.
Is this right or do I need to redo every thing?
confused I am
killerkilgore
confused I am
killerkilgore
