falconduvent
- Aug 13, 2007
- 7
Engine has been finnicky, cleaned carb, adjusted lean/rich, got the correct plugs, found the proper oil/gas ratio. First time it carboned up the #1 plug and burnt out the #2 plug (no spark). Changed the plugs and adjusted the lean/rich. @nd time, took it for a spin and it ran fine. Took it out a few hours later, got to the channel and opened it up, but it was already at full throttle, sounded like it was running one one cylinder, limped back to the dock. Checked plugs, couldnt start it after cleaning plug #1. The only remaining adjustment would be the points. How do I locate them, measure the gap and adjust them to the proper gap?
