Re: setting timing
Yes, it is possible to run the motor without a prop. If you have a big barrel you can have prop on as well (do NOT engage gear as it empty the barrel in no time). You could use muffs instead of a barrel (pretty noisy).<br /><br />A motor on muffs or in barrel with no load (in neutral or prop removed), should never be run above 'high idle' rpm.
