setting trim on 13 1/2 ft G3 ???
little-G3
help !I read my book , but still dont quite understand how much angle the boat sould have when cruising along the book said that 2/3 of the bottom should contact the water when cruising , I have a1970 13 1/2 ft Glasspar G3 with about a 1965 ( white stripe )65hp merc shortshaft with a dolfin . motor is a little big I know . at the last setting it would not plane out and the motor would rev up but not speed up , I moved the tilt up and now it starts to bounce the nose up and down in slitely choppy water at 3/4 throttel ,with me 180 lb & my 101 lb kid and a 6 gal gas tank up in the nose . how much boat should be in the water ????? HELP PLZ
Mercury140-I6
Re: setting trim on 13 1/2 ft G3 ???
I have found that (If you don't have Power Trim) from where it starts to bounce up and down, set it down until it stops doing that and it should be just right.<br /><br />Hope this helps.<br /><br />Craig
little-G3
I dont have power trim and the next peg down makes it push the nose down and moter revs but boat wont speed up . I think this thing should skip across the water, if I can get it set right . ps bought it in Marysville when I lived in Everett , I love lake Stevens .now im stuck in the rivers lol
achris
More fish than mountain goat
Easy to fix. Bin the fin!!<br /><br />Chris........
little-G3
lol put the fin on because the boat stood up on the tail ( 52 degrees ) at slow speeds , it was wild had to look around side of boat to see ! even standing on seat still could not see over bow .scarry as hell . and I do mean standing on seat .
achris
G3,<br /><br />The fin is what's causing all the handling problems at high speed. If you need something to get the bow down at low speed use trim tabs. They can be raised at higher speeds and won't mess with the backend.<br /><br />Chris...........
little-G3
trim tabs are those little *L* shaped things you bolt on the stern of the boat ???? <br />and should the bottom of the hull be flat in the water when cruseing or have a slight angle like 2inch rise in 4 foot ??? anyone ever have one of these little boats ?
little-G3
achris thank you for your help it is appreciated !
JB
Moving to Boats
