I have a question about set up. On one of my small inflatable boats at work, I have a Nissan 9.9 mounted. It is on a small 10' inflatable that can be handled by two firefighters at a scene. It is for a rapid response for ponds we have in the area. I also have a Zodiac FC-470 I set up for rescue and dive operations when something bigger is needed.
The smaller boat will run about 15 knots, but is almost scary at that speed. VERY twitchy. I also found, when running at that speed, I get a large amount of water spray from the shaft of the engine. Enough that it will spray over the transom, regardless of trim angle. It is a short shaft, which is the right measurement for the transom. What causes this?
It does it on the Zodiac also. I have a 25 HP Mercury 4S long shaft on it. It needs the long shaft to avoid cavitation. It will run about 20 knots wide open with a light load and trimmed out.
It is pretty cool being able to just hook up to the rescue boat and go out on the lake when things are going well. Doing some training.
