Re: setting up throttle cable
Not hard beertech....after the new cable is installed in the box and the box is mounted back in the boat, make sure the control handle is all the way back. At the engine, slip the casing guide hole, that's the black thing on the end of the control cable, over the pin on the engine throttle lever and set the retainer. Make sure the lever is all the way back against the stop. Pull on the throttle cable slightly to remove the slop in the cable and adjust the trunion thumb wheel on the throttle cable for a slightly snug fit in the trunion anchor. Put the trunion anchor retainer on. Should do the trick.
