Hello all, a few questions that I need help with...<br /><br />1) when smearing anti-seize on threads, how much is the right amount? do you smear 360 degrees around, and over the complete area of thread contact, or just a little bit and let it spread when tightening?<br /><br />2) how much threadlocker to use, complete coating or a little dab across the threads where contact will be?<br /><br />3) how warm will an outdrive get when hooked up to the muffs for flushing? Alpha 1, leg full down, idle speed.... should it get warm to the touch and have a little steam coming off of it if the air is cold outside?<br /><br />Thanks all.
