shaft extension 20hp johnson
rbyrum
i have a johnson 20 hp (R8545205)short shaft and want to change tolong shaft.any help would be appreciated.<br /> steve
Joe Reeves
Re: shaft extension 20hp johnson
The model number, not the serial number, will be needed so that we can determine the exact year.
rbyrum
the only other numbers i can find are on the transom mount,they are 188054and 01101
Joe Reeves
The plate on the transom bracket is the correct area. However, take a closer look at the number you list as 188054 which would be the model number.<br /><br />There is no such number in the book I have. Is it possible that the number is actually 18305 or 18503 ?
rbyrum
joe those numbers are stamped into the top of the transom mount.I see a place on the side where a plate could have been but its gone.
rodbolt
is it through hub exhaust with a splined prop shaft or a pin drive prop with an above the prop exhaust snout ?
rbyrum
it is through hub exhaust with a splined prop shaft
Joe Reeves
I understand the number problem. If that initial number you listed isn't from a core plug (looks like a small quarter size freeze out plug) on the powerhead, look for that core plug.<br /><br />If the number(s) on the core plug are different from what you stated initially, what are they?
Chinewalker
If I'm not mistaken, the "R" prefix usually means that it's a rebuilt or remanufactured powerhead. The model number may be lost to the sands of time on this one. The thru-hub exhaust narrows it down a little bit. Possibly late 1980s? If that's the case, pretty much all of the kits for the 20-35hp 2-cylinder thru hub exhaust motors from about 1985 upwards should work...<br /><br />- Scott
rbyrum
thanks for all the info guys.I guess ill call around and see if i can locate one.anyone have a part number?<br /><br /><br /> thanks again,<br /> steve
MarkCz
I bought a long shaft conversion kit for a 1985 20 hp outboard from this guy on ebay. email ariotti@tampabay.rr.com or call 727-442-4479 I understand that he had a few of these and a friend of mine purchases one from him a month ago.
rodbolt
the 99 accesories manual lists part 396707 for 20 to 35 from 85 thru 99.list in 99 was 232.74 dollars comes with everything you need except oxy/acetylyne to get the old stuff apart. try Ron's marine in portsmouth VA and tell him a guy in kitty hawk refered ya.
rbyrum
thanks rodbolt,i've already got it apart.i'll give him a call
rodbolt
the kit comes with new upper and lower mounts. the long shaft needs stiffer mounts than the factory short shaft. the mounts are sometimes difficult to remove.
