Re: Shaft length advice for Bass boat
If its a 92, it may be the "260", Which basically means it puts out around 260-ish horsepower. The downfall of the 260 is its charging system. It can barely keep up with all the accessories, trim, power jack plate, and you end up with an undercharged battery. The 260 also runs rougher at idle to mid-range. If it is the "280", it has a much improved charging system, engine idles and runs better in the low to mid range, and puts out roughly 280-ish horspower. You can tell the difference by popping the cowl off and looking at the top of the motor. A 280 will have an automotive style alternator driven by a belt, a 260 will have the under-flywheel type charging system.
The only reason I know this is because I just read about it in "Bass & Walleye Boats" magazine...:$
Another good thing about this motor is it weighs around 400 lbs. Show me any other big horsepower outboard that is that light...
