shallow-water boat recommendations?
jaymo
I'm fixing to buy a fishing boat for the outer banks of NC, where the water can get right skinny. I'm thinking simple, open CC. Outboard. <br />Any recommendations on make? Thoughts on jet-drive?<br />I've never owned a boat before.
epresutti
Re: shallow-water boat recommendations?
Jaymo,<br /><br />Check out this WEB site, lots of folks in tampa bay have Carolina Skiffs. Or do a GOOGLE search for "Carolina Skiff"<br /><br /> http://www.brechmarine.com/cskiff.htm <br /><br />Hope this helps.<br /><br />Safe boating to all.<br /><br />Cheers.<br /><br />emp.
jaymo
Thanks, Ed. CS is one of the boats I've been considering. I may want a bit more freeboard so that I can use the boat in the Chesapeake Bay where I live as well.
D
DJ
Guest
Jaymo,<br /><br />Scout is another I would consider. They are local, in that area, and have a great reputation.
Solittle
I have boated in the Chesapeake in the past and in Biscayne Bay, Florida Bay and the Florida Keys. I would recommend a 19-23' outboard powered CC. Less than 19' and you are going to get pounded in rough water and more than 23' can be a bear to trailer and launch/retrieve solo. I have a 23' Wellcraft with plenty of freeboard and you can always tilt the engines up when it gets real shallow. This also takes the rough water quite well.
FlyBoyMark
Ensign
Jaymo...Carolina Skiff is self bailing...how much freeboard do you want?
