bullsnot
- Aug 22, 2012
- 57
I had a suspicion that my shift assist wasn't working so I did the shift cable adjustment. Still difficult to take out of gear but I know the shift cable adjustment is spot on. Next I put the boat in high idle (1100 RPM) and manually flipped the spring on the shift interupt switch, no change to the way the engine was running. Should've dropped to about 500 RPM. Is it likely the switch itself or the shift assist module? Any way to test? Are there any aftermarket goodies to just make the whole thing better or cheaper replacement?
Thanks in advance for the replies.
1988 Bayliner 2455 5.7L OMC Cobra
