ericp501
- May 14, 2011
- 149
All my bellows were just replaced but the shift cable bellow seems to have a 1/4" slit just behind the clip on the narrow end which is letting a little trickle of water in. (at least I think thats where the little trickle is coming from, the flow fluctuates as you turn the wheel right and left).. I'm going to tape a string to the cable when I pull it to make my life easier when I put it back in, but are there any tips, tricks, or tools on how to tighten the bellow's clamp on the end that is against the transom? It looks like a really tight fit with no good angle for a screwdriver.
(no I can't have the person that did the bellow job fix it because I've since replaced my shift cable so he's pretty much saying its not his problem anymore, thats what I get for spending $250 on a bellow job)
