Mralph
- Jul 10, 2019
- 1
Working on my first boat ‘90 Wellcraft Eclipse 216 I bought a year ago. Just did gimbal bearing, u-joints and bellows. The trouble I’m having is getting the shift cable bellows to stay on the flange on the transom side. I’m about to redo it for the third time, the first time I had trouble keeping the boot on the flange and the clamp was going on crooked. Second time I cleaned everything up again and redid paying close attention to the amount of bellows adhesive I used and not tightening up the hose clamp until I let the adhesive setup for 2 hours. Also paying close attention to not over tightening the hose clamp. Everything looked good when done, took out and the bellows was almost off the flange again and letting water in. I do think the nylon zip tie on the small end might of been too tight and caused it to pull the boot off. My question is “Is there any tips or tricks to getting this boot to stay put? Is there a dimension on the how far the bellows should be out when clamp on small end?” Or anything else that might help. Sorry for the long winded explanation. Thank you in advance for any help.
