Re: Shift cable bellows
Depending on how much access you have to the rear of the motor you might need a guide.Heres what i do .
Remove the drive, remove the cable components from inside the boat.
remove slide with cable core ,and insert a weed whacker cord thru the cable and secure inside the boat leaving 4 ft extra outside
Unscrew cable and remove leaving the weed whacker cord in place cut away old bellows
slide weed whacker core thru new boot , and glue new boot in place.now slide weed whacker core thru cable and knot the end.
have someone pull from inside the boat untill core is ready to thread back in place.tighten cable, remove weed whacker cord, install shift core, reattach inside the boat, install drive and test.
