Shift cable drag/amount. Effort required to shift by hand during adjustment?
sledmonster
Hi All,
For those that have had a new cable installed and performed a adjustment. How much effort was/is required to shift the leg while someone is turning the prop?
I have a 1979 alpha one and 470. I am sure the cable is sticky etc. This of course creates the as discussed shifting issues that everyone seem to have problems with.
I need a miracle lubricant please.
To me it feels like 5-7lbs is what i need to shift during testing/adjustment.
Thanks,
Re: Shift cable drag/amount. Effort required to shift by hand during adjustment?
Hi All,
Thanks,
Ayuh,.... There ain't no short cuts, 'n there ain't no easy button...
Replace the lower shift cable as described in the service manual...:rolleyes:
sledmonster
Hi Bond-O
Thanks, for the reply.
I realise that the cable needs replacing.
But you didn't answer the question.
"For those that have had a new cable installed and performed a adjustment. How much effort was/is required to shift the leg while someone is turning the prop?"
Thanks,
Bt Doctur
once you install the plastic slide ,grease your thumb and index finger, gently hold the plastic slide , and shift the lower unit.
If your fingers slide, you need a new cable.
sledmonster
Thats a bit more like it. If I had 120 grit sand paper they would slide. I am in Yukon. I don't have a example to go "play" with. Yup it does need replacing. I am suprised it works as good as it does.
Now if only i had the parts.
Cheers,
