Hello all,<br />and thanks alot for all the help Ive had from you.<br />Ive come that far that my outdrive and bell housing is off, and now I need to replace the shift cable.<br />I read at mercstuff something that confused me a bit, and wondered if someone could help:<br /><br /> Pre-Alpha <br /> & Alpha<br /><br />This cable threads from inside of the bell housing. Boats which were made from 1965 to 1983 had cables which threaded in from behind the bell housing. These cables are no longer available<br /> http://www.mercstuff.com/shiftcable1.htm <br /><br />- Mine is threaded from behind I guess, (that is where the locker is), but when I look at the installation instruction it says that the one threaded from behind is the newer style, and the one threaded from inside the bellhousing is the older style.<br /> http://www.mercstuff.com/shiftcable2.htm <br />Does any one knows whats right, and which shift cable I should order, I also need a new shift cable guide and the slide, so maybe there is a kit that includes all those parts.<br />I can also see that there is a special tool for this, can I manage without?<br />
<br />Regards <br />Affa
