Hi, I’m new to the forum (and to boats) but you’ve already helped me with replacing the trim switches on my Alpha One sterndrive. Lot of work and a poor design IMO, but I digress…
I started having trouble with the engine dying when I shift into reverse and sometimes into forward. The general direction I get from past posts is it’s a lower shift cable problem. I have done a lot of reading to try and figure this out and have a few questions I was hoping you could help me with. First, I have a 1984 Sea Ray with an Alpha One Model 260R outdrive (SN 6779786 ) with a 5.7l V-8.
Thanks, Mike
- Before I start the major project of replacing the shift cable, could it be an idle speed/mix issue? I’m using the boat at about 5200’ elevation and it is carbureted.
- Sterndrive.com has a pretty through (and scary) description of the replacement process. Is it really that hard? While new to boats, I’m pretty good with other vehicles. Do I really need a special $40 9/16” deep socket?
- I have gotten conflicting direction on whether I need to know the cable length before ordering. Pro Bass said yes, Sterndrive said no. The manual appears to indicate the old style was no but the new style yes. I tend to believe the Sterndrive rep, but I’m so confused…
- This might be a better question for a separate post, but I have a “hard spot” in my shift command when I let off from full throttle. I really have to push hard to get past it. I assume the shift command has a separate cable for the throttle? Could this hard spot be related to the shift cable or would it be more likely to be the throttle (upper?) cable?
Thanks, Mike
