thunderroad
- Jun 19, 2005
- 417
160 mercruiser sn 2497444. Unhooking the cable and moving it by hand, I can get it to lock into forward with no problem but can only get it to the verge of going into reverse. It's like if I could only pull the cable another 1/8 inch it would go in. You can hear the gears touching as you turn the prop. When I had the drive off I remember thinking that the upper shift lever and shift slide seemed to be a pretty loose fit but really couldn't see anything that looked like much wear. Could it be that slop in that area is keeping it from engaging? <br />Any suggestions are appreciated.
