Anyone know if there is a way to replace the inner portion of the shift cable on a 1978 400 stringer? It has somehow got a slight kink and a bit of a fray up on the end inside the shift converter. The outer portion of the cable is still good.
Has anyone been able to repair one? ( silver solder, tig weld) Might sound crazy but if the repaired spot was kept small enough, it should still go around the pulley ok. And save about $500.
Thanks
Thanks
