Shift cable replacement in 3.0 mercruiser
lenny2113
Sometimes when I shift from forward to reverse the engine stalls. Sometimes it doesn't. :confused: <br />I don't know what the problem is but suspect shift cable. How involved is the change of shift cable? <br />I think it is upper shift cable that goes from shift control to the shift bracket (on top of valve cover).<br />I might be wrong about the cable also.<br /><br />Please help with suggestions?<br /><br />Thanks
The Marine Doctor
Re: Shift cable replacement in 3.0 mercruiser
Might be the shift interupter switch...it is designed to knock out a cyl or two..to assist in shifting. Try moving the Shifter arm quickly.<br /><br />TMD
