Flyin1500
- May 31, 2007
- 83
Howdy.
I have a 1984 Mercruiser 120 with an Alpha one drive. Recently it stopped shifting into forward gear, so I found a mechanic to come take a look at it. The shift cable needs to be replaced he says. Ok fine. Well it turns out that it is an older style cable that threads in the back....and I guess it's so corroded that even after hitting it with a torch, he can't get it out. Now I'm stuck with an outdrive that's off, no shift cable and no boat. I'm mostly venting, but I guess my question is, how can I get that thing out. The mechanic does not want to heat it up too much for fear of melting parts on the outdrive...which I think is good. Any ideas? Any good marine shops in the Seattle area? Thanks!
