Shift Cables
GA_Boater
Not really. The inner liner wears at the bends and lube may seem to improve operation for a short while. It's awful hard to lube a cable more than about 3 feet long and only the ends get any oil.
Old Ironmaker
Same goes for a steering cable. I'm sure there are self lubricated cables, I'm thinking Aircraft applications but I'm sure it would cost a few bucks. I've never had a shift cable stiffen up on an outboard. The mechanical connection at the engine can be adjusted and lubed though, look at that.
Aircraft cables are changed often
Change the cables
Chris1956
Shift and throttle cables should not need lubrication, however, some of them are able to be lubricated. Look closely at the cable end on the motor side. Some have an allen (OMC) or squarehead (Merc) set screw that holds the end to the inner wire. If the end can be removed, you can pull out the center wire and lube it.
