Shift cut out switch
Re: Shift cut out switch
Ayuh,.... What are your Issues Rick,..??..??
If your motor is cutting out, Stalling, when you shift Into gear,....
Your Lower Shift Cable is Junk,+ needs to be Replaced......
ziggy
what bondo said......
if ya really want to adj. it ya need a service manual so ya know how... to me. it's not straight fwd. so reading the procedure was necessary.... in my case....
might find yer sm here..... http://forums.iboats.com/showthread.php?t=251571
in the sm ya'll find out the exact method for adjustment.....
Bt Doctur
There`s no real service adjustment. the arm should be straight and the roller centered in the notch.
If it`s activating and stalling the motor when you shift into or out of gear it means the shift cable is bad or it`s way way out of adjustment.
RickW2007
well my boat wont shift with a load on it, on land it shifts fine just with more trouble going into forward but i launch it and it sticks in revers when i back it off the trailer
Don S
Start the engine, and manually activate the shift interrupt switch, does the engine stop?
